joe_wht
Jun 18, 2021Luminary
Ethernet Port link aggregation
I've been trying th Ethernet Port link aggregation & the 2.5 gig Multi gig port options. When trying the aggregation on mhy ReadyNAS 214 it Slows my web browsing & File access WAY DOWN!! When tryi...
Razor512
Jun 19, 2021Prodigy
For the QOS if set up properly, along with the right connection, it can work well.
One of the main issues with current implementations of QOS for all major routers, is the requirement that the upload and download throughput be specified. In my case, QOS works great since I have a fiber internet connection (verizon fios) where the throughput is consistent throughout the day. With some ISPs, e.g., some cable providers, depending on the area, and if there is any competition or not, you can be on an oversold node where the throughput fluctuates throughout the day. This means that whatever speed you set the QOS to, will be in accurate relative to the actual throughput.
While you can set the speeds to the lowest common denominators, it will mean that your speeds end up being capped by the QOS setting. Or if you set it to the average or peak speeds, then during the times when the set speed matches or is lower than the actual throughput, then QOS will actually perform some traffic shaping, but in the times when the actual throughput is lower than the QOS specified speeds, then even when enabled, the QOS will not have a noticeable impact on the connection, and it will not fix congestion issues.
If your ISP has very inconsistent speeds, then I recommend not enabling QOS, as you will end up with it not doing anything, or you will end up with it capping your speeds depending on the values set.
If your speeds are pretty consistent, then try enabling it and doing a few tests such as a large download while streaming video.
PS, for the nighthawk series, they still do not give granular control over the QOS entries, instead they use a L7 filter database where priorities are assigned to a huge range of traffic types, and it identifies the type of traffic and assigns a priority. While it is quite thorough, one area that I wish Netgear would provide more info on, is how exactly does it prioritize uncategorized traffic relative to bulk traffic. For example, if you are using some obscure service that is not in the database, and you are also downloading a bunch of games or anime, will the bulk traffic be prioritized below that of the uncategorized traffic?
joe_wht
Jun 19, 2021Luminary
Gottcha.. I'll leave it alone.
When I'm not home my cams are divided up between the 3 wifi networks.
When home only the front cams are on and 90% of what I use is ethernet connected.
I do have a lot of wifi plugs, all on 2.4 that are just sitting & waiting to be used.
Thanks so much for sharing your knowledge !!
- Joe
