pmokover
Feb 27, 2021Tutor
Ethernet Ports on RAX50 (AX5400)
Do the four Ethernet ports on the RAX50 (AX5400) router support PoE or PoE+? According to the specs on the Netgear website they do. That would be great if true but I'm guessing it's just a typo. S...
antinode
Feb 27, 2021Guru
> [...] See attached photo.
Which you found where, exactly? (Thanks for the helpful link.)
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get some. Read. Look for "PoE". (Prepare for
disappointment.)
