pmokover
Feb 27, 2021Tutor
Ethernet Ports on RAX50 (AX5400)
Do the four Ethernet ports on the RAX50 (AX5400) router support PoE or PoE+? According to the specs on the Netgear website they do. That would be great if true but I'm guessing it's just a typo. S...
Razor512
Feb 27, 2021Prodigy
The RAX50 does not have any POE ports, basically is is a single gigabit WAn port, and 4 LAN ports each at 1GbE.
If you need POE, then you will be stick with either getting PoE injectors or buying a basic POE switch.
If you end up going the PoE switch route consider getting something slightly higher end so that you have more room to grow.
