Motorray
Oct 16, 2019Tutor
everyday my nighthawk ax 12 drops internet speeds to 20mbps
first 3 days called for tech support and everytime we just have to reboot the router
Motorray
Oct 16, 2019Tutor
firmware is v1.0.1.8_1.0.39 for RAX200
modem is a cm1200
yes both over the wireless and connected to wired
yes all devices
yes when login to the nighthawk routerlogin and with speedtest.net
we pay for 300 and yes we have no problem with the old router and connected to the modem was just too slow
Oct 16, 2019Guru - Experienced User
I've noticed that the newer RAX devices firmware has been more beta than final version. I'd try reinstalling the firmware, factory resetting it, and starting back at stock. They seem to have issues whenever updates are done.
If that doesnt help,you can try downgrading a version on the firmware.
