bravovw
May 05, 2020Follower
Expanding Wifi Coverage by adding Router
Hi,
Im sure a similar question has been asked before but i was not able to find it while searching.
Problem: My combined modem/router from the ISP provider is broadcasting two networks, call them networkA-2g and networkA-5g. Because the modem's location, half of the house has poor connection to the wifi signal.
Solution: I am going to wire ethernet from the modem to the other half of the house, and am thinking I will connect to a netgear router, which will then give strong wifi signal for that half of the house.
Questions/Requirements:
1. I will still need the original modem to be broadcasting wifi, as well as the new modem? is that possible?
2. The new router i will have added can braodcast the same wifi networks(networkA-2g and networkA-5g)? or will have to be its own new network, EX. networkB?
3. Will the RAX40 do this job? is there a better piece of hardware for this application?
Thanks in advance
1 Reply
- Christian_RNETGEAR Employee Retired
Hi bravovw,
You may have the RAX40 set into access point mode so that the modem can do all the routing. However, you may also check/look into an extender an setting the extender into access point mode which will be hardwired to your modem/gateway. An extender like the EX8000 could do the trick.
Christian
