cadamski57
Jan 23, 2024Aspirant
Expect wifi speed for Nighthawk AX4
I have a Nighthawk AX4 model RAX40 router, purchased June 2023. I'm getting the expected 250mbps speed over ethernet. But even when my laptop is right next to the router, I'm getting 45mbps over wi...
- Jan 23, 2024
Depends, what wireless device do you have?
What does the wireless device support for connectivity between itself and the wifi signal?
Is it connecting to a 2.4 or 5Ghz signal?
Compare speed test results on other wifi devices.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.duckware.com/tech/wifi-in-the-us.html
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
cadamski57
Wifi was 2.4GHz. I changed to 5 and the speed jumped up to 250mbps. Nice. Thanks very much.
Jan 24, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
