STYXer
Jan 25, 2021Tutor
ExpressVPN on RAX80 (AX8)
Has anyone had any success setting up ExpressVPN on the RAX80 (AX8) router?
I see that it supports OpenVPN but I’m confused on how to get it working.
Thanks in advance.
Thanks in advance.
a couple things.
1. expressvpn is 3rd party firmware. You won't find help for it on the offical netgear forums
2. I don't see any supported AX routers for expressvpn currently
3. expressvpn has a list of supported models. and RAX devices aren't on there.
https://www.expressvpn.com/vpn-software/vpn-router
- STYXerTutorYes I understand all of those points, hence my question about asking for assistance. ExpressVPN supports OpenVPN and so does the AX8.
This being the case I imagine someone has figured out how to configure the AX8 using ExpressVPN configuration so that all devices connected can route through the VPN.- plemansGuru - Experienced User
So ask on the openwrt or expressvpn forum as those would be the forum for 3rd party support. NOT the official netgear forum.
