Wheaton
Nov 22, 2021Tutor
Extender compatability
I have a NETGEAR Wi-Fi Range Extender EX2700 that I would like to connect to my primary Wifi Route. I have a Cat6 cable to the basement that I can use to hard wire the extender. When I do that and configure the extender it knocks out the WiFi at the source. Are these two devices not compatible? or am I just not configuring them correctly.
Thanks
when you hardwire in an extender, you have to install it in access point mode. The ex2700 doesn't have an access point mode. Its literally the most base model device.
So it can't be hardwired into a router.
Sorry.
- WheatonTutor
Thank you for your response. I'm confused as to why the EX2700 have a network cable port if it can't be set up as an access point?
Also, if this extender can't be user, what extender would you recommend with my WiFi Router?
Its used to connect pc/laptops/other wired devices to it.
What are you looking for in an extender?
Single band?
Dual band/triband?
What speeds are you wanting/expecting?
You can view through netgears line of extenders and sort by features you're wanting.
https://www.netgear.com/home/wifi/range-extenders/
I do warn people that single/dual band extenders do drop throughput 50% (for devices using the extender) because they have to use the same chip to go router----->extender and then extender----->devices. And they can't do both at once.
