Patrick99999999
Jan 21, 2020Guide
Extending a wireless network based on Nighthawk AX12 12-Stream Tri-Band Wi-Fi 6 to other buildings
How do I extend a wireless network based on Nighthawk AX12 12-Stream Tri-Band Wi-Fi 6 to other buildings where a wifi signal is not available. I have CAT6 cables to the buildings from the base stati...
- Jan 21, 2020
Thank you - you are right. Many thanks for sharing your view.
Newfiedrool
Jan 21, 2020Virtuoso
The Ex8000 I use allows smart roaming too. Don't forget I'm using an AX12 unit too but here's the thing do you need ax or ac at the moment and do you want to buy the latest tech but maybe find it's not fully needed.
its really down to you all I'll add is I'm really happy with my extenders, super performance and no hassle.
Patrick99999999
Jan 21, 2020Guide
- NewfiedroolJan 21, 2020Virtuoso
Let us know what you get, alway nice to see how it pans out.
