NetguyKB
Aug 21, 2020Aspirant
Extending the AX6000 WiFi Cable Modem Router
Hey folks I just purchased a NEW AX6000 WiFi Cable Modem Router. I would like to know if there is a way to EXTEND the WiFi signal even farther than what its capable of doing by adding a WiFi extender...
NetguyKB
Great advise thank you. Whats the difference between 4 stream and 8 stream based on the two AX devices - EAX20 and EAX 80
Aug 21, 2020Guru - Experienced User
Main difference?
EAX20: 5ghz speed is 1.2gig
EAX80: 5ghz speed is 4.8gig.
That's link rate, not actual throughput
