Raven2099
Mar 18, 2022Aspirant
extent the signal streath to cover house RAX35v2
I was wondering if there was a way to extent the signal streath to cover my entire house about 1500 sqr feet
1 Reply
Your home is 1500sq ft?
If so, and that router is centrally located, it should cover the home.
What is your homes interior walls made of?
Do you have it centrally located?
If you're just looking for extenders, netgear has a whole line of of them from older devices to the newer AX devices like your router.
https://www.netgear.com/home/wifi/range-extenders/
