Bemo
Aug 04, 2020Tutor
Faster speeds on RAX50 app than on devices
I have a Nighthawk RAX50 and have the 1GB speeds through Cox. I'm getting those speeds through the netgear app but not on any of my devices, wired or wireless. I've tried testing on numerous differen...
Bemo
Aug 04, 2020Tutor
I should add a couple things..
I've tried changing the 5GHz channel but not really sure which one is best.
Modem is an Arris SB8200.
Firmware update is V1.0.2.64_2.0.41
Aug 05, 2020Guru - Experienced User
What speeds do you get directly connected to the modem?
make sure to disable qos, traffic monitoring, parental controls.
If you haven't, try a simple factory reset and reinstall with leaving most settings default.
Are you using ipv6?
And then make sure to speedtest over a hardwired connection. many things impact wireless speeds.
- BemoAug 07, 2020Tutor
I am getting the correct speeds now. Roughly 700 download on both the app and devices. Finally!
I am not using IPV6.
The issue I'm running into now is experiencing packet loss during online gaming and what I can assume is leading to issues with video chatting or conference calls. Is this something that can be fixed within the router's settings?
- plemansAug 09, 2020Guru - Experienced User
Are you getting the packett loss over wifi or wired?
Does it happen if you're hardwired into the modem?
- BemoAug 16, 2020Tutor
It happens when I'm hardwired in. I have not tried connecting directly to the modem. I don't have a ethernet cable that long. It would need to be 150+ feet
