thehypnootoad
Feb 23, 2021Luminary
Faulty rax120 netgear tech useless
Had RAX120 for a week know that seems to have nothing but issues router power cycles evertime you make a change (power button flashing for 3 minutes). Devices connect and work all day till i change some thing like dmz, router will power cycle again and that device refuses to connect.
Have done following
Dropped wifi back down to ac
Ftfp with newest firmware and previous
Reset for 30 seconds
Firmware update and dropped none ftfp
Trying to rma but getting nowhere.
Have done following
- thehypnootoadLuminaryManaged to get most wifi devices to connect via making a static connection ip. So there must be dchp issue on these routers.
- Christian_RNETGEAR Employee Retired
Hello thehypnootoad,
Please continue to work with our support team regarding your issues with the RAX120.
Christian
- thehypnootoadLuminaryThank you christian would it be possible to delete this thread thank you.
