Feste's avatar
Feste
Initiate
Aug 29, 2022
Finally figured out how to change device priority in QoS settings on nighthawks
You have to check mark the box beside each device on the QoS page, then "edit" at the top of the screen is no longer greyed out. Click edit, and you can change a single device's priority. Painful bec...
