nextyear58
May 22, 2023Tutor
Finding my WiFi
I purchased a new Netgear Nighthawk AX12 WiFi router to replace my older Netgear Nighthawk X6 AC3200 Got it hooked up and everything works perfect, including wifi to all my devices. Including Sony TV...
May 22, 2023Guru - Experienced User
AX12 isn't a valid model #. RAX?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Make sure the wifi adapter drivers on the laptop are up to date.
Contact the Mfr of this laptop for help and support regarding there product.
