nextyear58
May 22, 2023Tutor
Finding my WiFi
I purchased a new Netgear Nighthawk AX12 WiFi router to replace my older Netgear Nighthawk X6 AC3200 Got it hooked up and everything works perfect, including wifi to all my devices. Including Sony TV...
May 22, 2023Guru - Experienced User
nextyear58 wrote:
I have also went through the driver updates and uninstalling and installing.
Thank you, Mike
If you got it direct from realtek, might be time to replace that wireless card. No point holding back your networks performance (by disabling the routers AX) because of old technology that realtek doesn't support anymore.
A bunch of videos online for replacing similar toshiba laptops.
Some laptop makers restricted what cards could be used and had a whitelist for cards that'd work but I didn't find much for that laptop.
- nextyear58May 22, 2023Tutor
I edited my post with ser # and corrected the ser #
I will look at replacing the card as suggested and up date my post soon.
Worst case scenario is, it does work with the dongle.
Thanks again, Mike
