nextyear58
May 22, 2023Tutor
Finding my WiFi
I purchased a new Netgear Nighthawk AX12 WiFi router to replace my older Netgear Nighthawk X6 AC3200 Got it hooked up and everything works perfect, including wifi to all my devices. Including Sony TV...
May 22, 2023Guru - Experienced User
A bunch of videos online for replacing similar toshiba laptops.
Some laptop makers restricted what cards could be used and had a whitelist for cards that'd work but I didn't find much for that laptop.
nextyear58
May 22, 2023Tutor
I edited my post with ser # and corrected the ser #
I will look at replacing the card as suggested and up date my post soon.
Worst case scenario is, it does work with the dongle.
Thanks again, Mike
