Driver6422
Oct 29, 2019Follower
FireCube Apps not working with Nighthawk AX600 after firmware update.
New to this!!! Bought this NETGEAR AX8 8-Stream router a few months ago (over 90 days) to try and help manage all of the devices now filling my home. A couple of days in I realized my Netflix, H...
Oct 30, 2019Guru - Experienced User
The manual walks you through manually updating firmware on page 99 of the manual. You can use this and instead of slecting the most recent firmware, you can use the prior firmware to downgrade to. Older firmware can be found on the support site under downloads +view previous versions.
Anytime you change firmware, make sure to do it over a hardwired connection. Make sure to factory reset after downgrading as well. In fact, to me the RAX devices have responded well to factory resets anytime the firmware has been changed. It might be worth trying that first (as you'll need to reset after the downgrade anyway).
here's the support site.
https://www.netgear.com/support/product/RAX80.aspx
