CA69
Jan 08, 2024Initiate
Firmware 1.2.9.52 keeps freezing every other day
Any news on this issue? "RAX120 on Firmware 1.2.9.52 keeps freezing every other day" Same issue here including the Ethernet traffic freezes
CA69
Jan 09, 2024Initiate
-Confess my unit was bricked during a previous fw update due to power shortage but I manage to get it running with instructions on YouTube. No issues after that until this fw. No issues to perform update latest fw during but after this fw update problems occurred. I have reinstalled the latest fw again without improvement.
-cant access that info at the moment
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
-cat 5e used, installed 12 year ago entire building
Are you using the yellow WAN port or the Multi-Gig port for the connection between the router and your modem/ONT?
-using the yellow port for Internet from ONT
What all do you have connected to the router?
- Three Netgeat switches
- EAX80 Nighthawk AX6000 connected with Ethernet as in Access Point Mode with identical SSID and pw. Latest FW V1.0.1.70_1.0.2
- Two Apple TV
- Three TV
- Receiver/
- Smart home units like Philips hue, approximately 35 units in total, HomeKit, Netatmo-Doorbelll, Netatmo-Presence, Meross_Smart_Plug, IKEA , Telldus, YALE door lock, Google Nest Hub, Crome Cast
- Four video cameras
- Two NAS
- Two gaming PC
- XBOX, PS, Nintendo
- Three MacBook
- Two PC laptop
- Five iPhone
- Five IPAD
- Printer
- Two wifi speakers
How many devices are connected at one time?
-39 currently but I believe can increase
Does any of the top LEDS turn AMBER when this happens?
- will check
Does the top of the router feel extra warm or hot when this happens?
- Hot for sure but hotter I difficult to determine, 2 hrs after boot CPU 34%, Memory used 421MB/869MB, Flash usage 233/151MB, Yesterday when I checked the CPU load was 75% some hrs before ”issues” This "issues" might be heat/load issue!?
Might try a Factory reset and setup from scratch as well if this continues.
- Will try
Jan 09, 2024Guru - Experienced User
-cant access that info at the momentPlease give feedback when you can.
-cat 5e used, installed 12 year ago entire buildingCAT6 UTP Would be recommended since your using the yellow WAN port.
- Three Netgeat switchesModel # of these switches please.
- EAX80 Nighthawk AX6000 connected with Ethernet as in Access Point Mode with identical SSID and pw. Latest FW V1.0.1.70_1.0.2Might turn this OFF and test with out the EAX 80 online to see if problems still are seen with this version of FW.
- Two Apple TV
- Three TV
- Receiver/
- Two NAS
- Two gaming PC
- Three MacBook
- Two PC laptop
- Five iPhone
- Five IPAD
- Printer
- Two wifi speakers
-39 currently but I believe can increaseThats a fair amount for sure...
Does any of the top LEDS turn AMBER when this happens?- will check
Please.
- Hot for sure but hotter I difficult to determine, 2 hrs after boot CPU 34%, Memory used 421MB/869MB, Flash usage 233/151MB, Yesterday when I checked the CPU load was 75% some hrs before ”issues” This "issues" might be heat/load issue!?Yes, if the CPU is getting this high, something maybe failing or causing the higher load to go up.
There is a Fan check feature in the debug page, please check this and enable the internal fan.
- Will tryPlease let us know the results. Just reset and setup from scratch and don't use the EAX80 for now.
Enable the internal fan as well and please keep track of the CPU and memory usage.
Can you reduce the amount of devices connected if possible with leaving only most important and critical devices connected to see if the CPU load goes up after watching and tracking it?
