jkk4_1998
Feb 09, 2021Apprentice
Firmware 3.2.17.12. Update for Orbi app
So, I do not want to manually download the latest firmware. I've always done it thru the Orbi app on my iPhone. Anyone know when Netgear plans on releasing this update via the app? Current firmware o...
Christian_R
Feb 12, 2021NETGEAR Employee Retired
Hi jkk4_1998,
Have you had a moment to reinstall the Orbi app and/or power cycle your router?
Christian
- jkk4_1998Feb 12, 2021Apprentice
Hi Christian, just did all that and still doesn't show the new firmware.
- Christian_RFeb 15, 2021NETGEAR Employee Retired
Hello,
May you check to see if you're able to update the firmware by visiting the admin page via web browser (orbilogin.net).
Thanks,
Christian
- jkk4_1998Feb 15, 2021Apprentice
Hi Christian, I am only able to manually download the updates in orbi login. If I do the auto check, it still list my current firmware and not the new. You know, with all the Netgear routers I've owned, probably 4-5, I have always done the manual updates. I was just hoping that now that I've got the Orbi, that it would do the auto update on the Orbi app. After all, I did update to my current firmware with the Orbi app. So why have things suddenly changed?
