GoldenJ
Aug 28, 2023Guide
Firmware cannot be updated on RAX45
My RAX45 router is running firmware is v1.0.11.112. The Netgear prompts to update the firmware to v1.0.12.120. First, I used the Firmware Update Assistant. The process was stuck in the middle, the we...
- Aug 29, 2023
FURRYe38 wrote:
One can skip over FW version and go directly to v.128.
Not much use if it is the update process that is failing.
But that was why I first suggested it.
michaelkenward
Aug 29, 2023Guru - Experienced User
- GoldenJAug 29, 2023Guide
Yes. Does it fix firmware update issue? I did not see that it will resolve the issue that FW cannot be updated. If it does, do you suggest updating FW with this FW from v1.0.11.112 by skipping v1.0.12.120?
- FURRYe38Aug 29, 2023Guru - Experienced User
- michaelkenwardAug 29, 2023Guru - Experienced User
Without knowing exactly what you did, and no useful error messages, it is hard to diagnose what happened.
I assume that this is the process you used:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
If the "Hotfix" fails then it is the process rather than the firmware. (I assume that you tried a different download.)
One thing that can unstick a reluctant update it to reset the router before you try the update.
You could create a backup of your existing configuration before you make the plunge.
