GoldenJ
Aug 28, 2023Guide
Firmware cannot be updated on RAX45
My RAX45 router is running firmware is v1.0.11.112. The Netgear prompts to update the firmware to v1.0.12.120. First, I used the Firmware Update Assistant. The process was stuck in the middle, the we...
- Aug 29, 2023
FURRYe38 wrote:
One can skip over FW version and go directly to v.128.
Not much use if it is the update process that is failing.
But that was why I first suggested it.
michaelkenward
Aug 29, 2023Guru - Experienced User
GoldenJ
Aug 29, 2023Guide
Yes. Does it fix firmware update issue? I did not see that it will resolve the issue that FW cannot be updated. If it does, do you suggest updating FW with this FW from v1.0.11.112 by skipping v1.0.12.120?
