GoldenJ
Aug 29, 2023Guide
Firmware cannot be updated on RAX45
My RAX45 router is running firmware is v1.0.11.112. The Netgear prompts to update the firmware to v1.0.12.120. First, I used the Firmware Update Assistant. The process was stuck in the middle, the we...
- Aug 29, 2023
FURRYe38 wrote:
One can skip over FW version and go directly to v.128.
Not much use if it is the update process that is failing.
But that was why I first suggested it.
Aug 29, 2023Guru - Experienced User
GoldenJ
Aug 29, 2023Guide
FW was successfully updated to v.128. Thanks for help!
- michaelkenwardAug 29, 2023Guru - Experienced User
Well done. Always nice when the simplest option works.
- GoldenJAug 29, 2023Guide
Thanks so much again! I am curious why v.128 is called HOT FIX.
- FURRYe38Aug 29, 2023Guru - Experienced User
Apparently these were high priority items:
New Features:
- Support Speedtest server selection in web GUI.
- Support Unicode character for attached device name and router name.
Bug Fixes:
- Fixes the issue where USB stick can remove even files still in transmission.
- Fixes the issue where FW cannot restore by old configuration.
Security Fixes:
- This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security
