midnttigr
Apr 29, 2021Aspirant
firmware not updating
I went to check for any new firmware updates...says that firmware 1.0.3.106_1.0.58 and it says it is downloading yet it doesn't download...this is the current firmware version I have V1.0.3.102_1.0.5...
Apr 30, 2021Guru - Experienced User
Try installing it manually.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
- midnttigrApr 30, 2021Aspirant
the newest version isn't listed anywhere I checked if not I wouldn't of posted this
that version is not what my router is telling me is the latest update
- plemansApr 30, 2021Guru - Experienced User
I'm showing the .106 for the manual update as available.
