cnvincbl1
Jul 07, 2020Follower
Firmware Release schedule
I am interested in know what schedule are firmwares released. When will the next release be available for the RAX120. I updated the RAX80 which I had before the RAX120, and replaced the router at m...
avtella
Jul 08, 2020Prodigy
I have multiple laptops with the AX200, they connect at HT160 link rates, and more importantly than the link rates they get about 1,200-1400 Mbps in real world transfers on LAN and 1.15-1.2 GBPs on WAN transfers.
I wonder if you are using the upper 5Ghz channels that don’t have HT160 support. For any router it’s best to use the lower channel numbers for HT160.
The middle channels ie 100-120 area is not as good as the 36-54 area either regardless of model.
