Elvis13
Nov 22, 2021Tutor
Firmware Update : GUI Language Invalid
Hello, I own a Nighthawk RAX45 router where I am trying to update the firmware version: Current Firmware Version 1.0.2.82 New Firmware Version 1.0.4.100 However, whenever I try ...
- Nov 27, 2021
Tried a factory reset and setup from scratch then go right in and try to manually update FW?
What happens if you try installing 1st FW version on the router then reset and setup from scratch and walk thru the set up wizard?
Elvis13
Nov 28, 2021Tutor
Hi Furry,
I did exactly as you suggested and did a factory reset. Once this was completed, I was able to manually update the firmware. As this update is critical due to recent hackng, it was vital to get completed. Thanks for your guidance.
Happy Hoidays to you!
Elvis13
Nov 28, 2021Guru - Experienced User
Enjoy.
- GigiSDec 03, 2021Tutor
I did a factory reset to resolve the issue. The upgrade is finally done
- FURRYe38Dec 03, 2021Guru - Experienced User
Enjoy.
