Elvis13
Nov 22, 2021Tutor
Firmware Update : GUI Language Invalid
Hello, I own a Nighthawk RAX45 router where I am trying to update the firmware version: Current Firmware Version 1.0.2.82 New Firmware Version 1.0.4.100 However, whenever I try ...
- Nov 27, 2021
Tried a factory reset and setup from scratch then go right in and try to manually update FW?
What happens if you try installing 1st FW version on the router then reset and setup from scratch and walk thru the set up wizard?
GigiS
Dec 03, 2021Tutor
I did a factory reset to resolve the issue. The upgrade is finally done
Dec 03, 2021Guru - Experienced User
Enjoy.
