Elvis13
Nov 22, 2021Tutor
Firmware Update : GUI Language Invalid
Hello, I own a Nighthawk RAX45 router where I am trying to update the firmware version: Current Firmware Version 1.0.2.82 New Firmware Version 1.0.4.100 However, whenever I try ...
- Nov 27, 2021
Tried a factory reset and setup from scratch then go right in and try to manually update FW?
What happens if you try installing 1st FW version on the router then reset and setup from scratch and walk thru the set up wizard?
WayneButscher
Jan 02, 2022Initiate
I had the same problem with the GUI language. I just went to the support page and downloaded the firmware Zip file. Then unzipped it to a folder on my desktop (in my case it was RAX50-V1.0.5.106_2.0.70.chk). Then went back into Administration Area and Firmware update and clicked Browse and directed it to the location of the update (RAX50-V1.0.5.106_2.0.70.chk).
Wayne
Elvis13 wrote:Hello,
However, whenever I try to update on a direct connection using my PC, I get the below mesage and am redirected back to the Internet set up tab:
"GUI language file is invalid"
How should I proceed?
Thanks,
Elvis13
