Elvis13
Nov 24, 2021Tutor
Firmware Update : GUI Language Invalid
Hello, I own a Nighthawk RAX45 router where I am trying to update the firmware version: Current Firmware Version 1.0.2.82 New Firmware Version 1.0.4.100 However, whenever I try ...
JDT2
Dec 29, 2021Aspirant
This problem has shown up repeatedly with the number of posts jumping on the most recent models. It's a bit like an update to Android or iOS failing. It shouldn't happen. There are a handful of suggestions (none apply in my case) but you're welcome to try them:
- https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX20-Firmware-Upgrade-Failure-1-0-3-96-2-1-46-1-GUI-Language/m-p/2130164
- https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Nighthawk-RAX45-Firmware-update-failure-with-quot-gui-language/m-p/2156357
- https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Firmware-Update-GUI-Language-Invalid/m-p/2166449
- https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Nighthawk-RAX45-AX4300-will-not-complete-a-firmware-upgrade/m-p/2169755
- https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-AX-AX4300/m-p/2166075
- https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Firmware-upgrade-AX4300/m-p/2050364
