Poison_6022
Jan 10, 2022Tutor
Firmware Update Bricked MR60 Router
Yesterday evening I was experiencing some difficulty with stable conections to Google Chromecast 3 units that I was trying to set up in our basement rec room and guest bedroom. After giving up on th...
Jan 10, 2022Guru - Experienced User
the only other things I'd try would be nmrpflash.
https://github.com/jclehner/nmrpflash
If that doesn't work, i'd start a support case (if you're in warranty) or return it to where you got it
