judddonnelly
Mar 23, 2020Follower
Firmware Update causes Internet to go out
After I did a firmware update my router sporadically drops the internet. Intersting alos that when I can get into the config page I'm prompted to use the nighthawk app. Did this firmware app include something to force the use of the app?
1 Reply
Did you have issues prior to the update?
any time you have issues after a firmware upgrade, a good first step is to factory reset and manually re-install the router (not from backup).
Have you tried this?
