dmt7079
Nov 08, 2020Apprentice
Firmware update issue NETGEAR RAX35 Nighthawk AX4 4-Stream WiFi 6 Router
I currently have a help desk ticket open and there has been no reply. I updated the router with the latest firmware update V1.0.3.80 and it wont save the changes that are applied on the router, espec...
Nov 09, 2020Guru - Experienced User
during any of these firmware changes, did you factory reset and do a clean install on the router? If the firmwares changed enough, a factory resets clears old/bad settings. its also why a clean install (not from backup) can help.
I'd try that if you're having issues after firmware changes.
