shirsc
Nov 21, 2022Tutor
Firmware update V1.0.13.128 killed my internet access
The RAX70 router recently prompted me to update to firmware version V1.0.13.128 from V1.0.12.114. The update killed my internet access. It seems that the new firmware fails to handle my ISP DHCP lea...
Nov 21, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- microchip8Nov 22, 2022Master
A 30 minutes lease means the router has to update it every 15 minutes. It might be (not sure) that this lease is too low for the new firmware.
If it was previously working on the older firmware, you might revert to it while in a future version the issue is resolved.Also, a factory reset and then loading up the new firmware might fix the issue...
- shirscDec 12, 2022Tutor
I'm now second guessing the culprit being the firmware update. Before the update was initiated, I tried to do a large copy of files from my laptop to the connected USB drive on my RAX 70 router. The file copy was initiated on a laptop with Wi-Fi, but it was taking forever and I got several errors on some files. I eventually attached the laptop to the router via a CAT6 cable to try and help the file copy go faster. I recall finally giving up after waiting for a very long time. Then I performed the firmware upgrade and that is when the internet connection problems started.
Since I thought I was having the internet problems with the new firmware upgrade, I downgraded to the previous firmware version. I no longer had the Internet connection problems, but I also had not reattached the USB drive to the router. My assumption at that time was that the new firmware had caused the Internet connection problems.
At that point, I followed the advice on this message board to completely reset the router to factory defaults. Then I installed the latest firmware. I reconfigured the router and everything was working great. However, I had not attached the USB drive to the router. The router was running for several days without any issues at all using the new firmware. However, I attached the USB drive to the router yesterday, and once again it started having Internet connection problems. I wonder if this software is somehow getting consumed with some random accesses to the USB drive and not updating the DHCP request for a new IP address from the ISP?
I'm using a Seagate USB drive that is 6 terabytes. It has been working without issue for at least a year on my RAX 70 router. My USB drive works fine when I connect it directly to my laptop.
I need the USB drive to work on the router for network storage and Windows backups. I need to know why I lose the internet connection periodically if I attach the USB drive to the router!!!!
Correction – my external USB drive is a 6TB Western Digital “My Book”
