Loverdover15
Jun 29, 2022Follower
Firmware update
Needing to update my router with new firmware
Jun 29, 2022Guru - Experienced User
what router?
are you trying using the built in auto-update or manually?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
