liv2hunt
Feb 02, 2021Tutor
Firmware upgrade AX4300
I am attempting to update the firmware on my AX4300 router but keep getting the message "GUI language file is invalid". I also attempted to update the firmware manually but that didnt work either. ...
liv2hunt
Feb 02, 2021Tutor
plemans, thanks for responding. My actual model is RAX45. Sorry for the incorrect number before.
I was able to finally get the update installed. Not sure what the issue was previously as I used the same file that I had tried before but this time, it completed the update.
I am still trying to figure what is causing the disconnect from the internet. Any ideas.
Feb 02, 2021Guru - Experienced User
what actual firmware did you install?
What modem is it connected to?
After the firmware update, did you try a factory reset and clean install (not from backup)?
The rax devices were released even before the AX spec was finalized. For some reason they respond favorably to factory resets.
- liv2huntFeb 03, 2021Tutor
I installed Firmware Version V1.0.2.82_2.0.50.
Connected to a
SURFboard® SB6183 DOCSIS 3.0® Cable Modem
as far as the factory reset and re install, I have not done so. It is currently working and I will wait to see if the simple firmware update helps before going to the factory reset procedure.
Thanks for the help
