cestmoijay
Dec 13, 2021Aspirant
Firmware upgraded to 1.0.4.100_2.0.64 & Remote Management (or Web Services Management) shows nothing
Hello I just upgraded my AX4300 (RAX45) from 1.0.2.82_2.0.50 to 1.0.4.100_2.0.64 and when I navigated to Web Services Management section to see if it's enabled or not, and lo and behehold, I can ...
michaelkenward
Dec 14, 2021Guru - Experienced User
cestmoijay wrote:
I can only see "Always Use HTTPS to Access Router"... nothing else!
Have you tried disabling that?
Netgear has been messing around with these things, pushed partly by people who insist that "http" access is dangerous. (It isn't really when you are on a local network.) I turned it on for a bit and things started to go wrong.
Netgear has also been changing various cloud services. Sometimes it presents this as a security issue, but it can also be down to changes at the supplier end. For example, it has killed free parental controls.
These changes usually get mentioned in the release notes for new firmware.
Remote management still works here in the R7800.
If it is important to you, then try rolling back to earlier firmware to see if that works.
You are not the first person to ask about this.
Search - NETGEAR Communities – Remote Management
