RBuster
Jun 18, 2021Aspirant
Fixed WiFi signal from Ferrett camera to mesh?
I have a Ferrett camera which puts out a fixed Wifi signal. The signal is line of site and the range is 20 feet. Can it be connected to any of the Netgear extenders? My application is abnormal. I...
RBuster
Knowing NOTHING about Wifi connections, Ferrett's extender fix is a memory stick type of device which extends the distance to double if it can be placed in the center of the camera and phone. It also is limited to line of site - which is a problem for me.
It seems logical to me that they would design an extender which would be stronger and not rely on line of site. - which leads me to question if the technology allows the "fixed" system to be extended with the mesh.
Jun 18, 2021Guru - Experienced User
You might be better to ask on the Cable ferret's forum or customer service on ways to expand their setup
