BandD
Dec 21, 2023Aspirant
Follow up post installation
I do not have a smart phone. I borrowed a smart phone for installation purposes. Now, without access to a smart phone, how do I 'check up' on my modem should I want to for any reason? Thanks, Bob...
michaelkenward
Dec 21, 2023Guru - Experienced User
Which equipment have you installed?
A router? Modem? Modem/router?
They can have different ways in.
Mobile phones are necessary for most things you can do. Some of us avoid mobile access wherever possible.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
BandD
Installed Nighthawk Netgear42 router.
Have read the Manual - with my 2nd grade level knowledge of computers, the Manual is like a foreign language to me.
- microchip8Dec 21, 2023MasterNetgear42 is NOT a router model! Look at the device's label underneath!
