xtramm
Nov 24, 2020Initiate
force device to connect 5ghz wifi
MY MODEL IS NIGHTHAWK MK42 (MR60 on admin page), firmware V1.0.6.102_2.0.45 (not found in list) often (not always) my 5gz devices connect over 2.4ghz wifi. i want to force several devices to conn...
rinthos
Nov 26, 2020Luminary
You've got the WiFi Mesh System is looks like. Sorry to say that currently Netgear's Mesh solutions (ORBI, Nighthawk MK series) have a feature called "Smart Connect" also known as Band Steering. This feature is exactly what you mentioned, the router using both 2.4ghz and 5ghz under the same SSID. In theory, the "best" decision is assumed to be made...that is, the intent is that you should not need to worry about this, and the router and devices will just work it out.
There have been rumors that Netgear may add the capability to turn off this feature in the future for these devices, but no guarantee.
You may want to get a conventional Netgear router such as the RAX50, RAX70, RAX80, RAX120, or RAX200 where the feature can be enabled/disabled on-demand. You can then add EAX80 range extenders if needed. Not as seemless as a Mesh solution, but it will allow you to separate out the SSIDs as you are trying to do.
I know it's not the answer you were looking for, but it's just the reality of the Netgear "mesh" product lines, at least as they exist today :(.
xtramm wrote:MY MODEL IS NIGHTHAWK MK42 (MR60 on admin page), firmware V1.0.6.102_2.0.45 (not found in list)
often (not always) my 5gz devices connect over 2.4ghz wifi. i want to force several devices to connect in 5ghz or verify and choose myself with different ssid name for 2.4ghz and 5ghz wifi.
how can i do that?
thank you
