Llamaduck
Mar 05, 2025Aspirant
Frequent disconnects with nighthawk ax6 5400
I previously had a netgear router that worked well until I updated the firmware. I replaced the router with a new ax5400 and the internet connection will drop randomly. It seems to happen most with ou...
Mar 05, 2025Guru - Experienced User
1. what modem/gateway is it connected to?
2. what router is it? Those are speeds/references, not model numbers.
3. what firmware are you on? "The latest" isn't always the latest or has other issues.
4. Wired devices don't drop? Just wireless?
Llamaduck
We have fios but I can't find a model #, possibly it's on the back but it's wall mounted so I don't want to mess with it.
Netgear model rax50v2
Firmware 1.1.4.28
All my other wireless devices are OK except for 2 android phones.
Firmware 1.1.4.28
- FURRYe38Mar 05, 2025Guru - Experienced User
Any chance Protection Engine is enabled on the RAX router?
- LlamaduckMar 05, 2025AspirantI don't see that options but if it's the armor protect, I already turned it off.
Just had a long chat with netgear support. Their solution is to turn the cellular data off on the phones to force it to stay on wifi. I'll give this a try but seems like an annoying work around- FURRYe38Mar 05, 2025Guru - Experienced User
PE would be on the RBRs web page under Advamced tab/Security...
