AlMat_1
Jan 19, 2021Follower
Frequent IP address conflicts on RAX80 net, even with defined device ip addresses???
Hi guys, I have RAX80 router behind AT&T ADSL router. It works OK, but has quite frequent problem with assigning same IP address to different devices. I've set it up to provide pre-defined IP add...
Christian_R
Jan 22, 2021NETGEAR Employee Retired
Hello AIMat_1,
Can you confirm that the AT&T router is in modem/bridge mode only.
Thanks,
Christian
