AlMat_1
Jan 19, 2021Follower
Frequent IP address conflicts on RAX80 net, even with defined device ip addresses???
Hi guys, I have RAX80 router behind AT&T ADSL router. It works OK, but has quite frequent problem with assigning same IP address to different devices. I've set it up to provide pre-defined IP add...
antinode
Jan 22, 2021Guru
> I have RAX80 router [...]
Firmware version? Configured as a router? Connected how, exactly?
> [...] behind AT&T ADSL router. [...]
Maker? Model number? Which way is "behind"? What, exactly, is
connected to what, exactly? (Hint: If a device has different types of
Ethernet ports, then "connected to device" is not enough detail.)
> [...] quite frequent problem with assigning same IP address to
> different devices. [...]
Netgear router firmware may be buggy, but the usual explanation for
that sort of behavior is having multiple DHCP servers on one LAN
segment.
> How can I fix this and have stable IP addresses for all my devices?
If your (unspecified) "AT&T ADSL router" is configured as a
modem+router, then you might want to configure the RAX80 as a wireless
access point. Visit http://netgear.com/support , put in your model
number, and look for Documentation. Get the User Manual. Read. Look
for "Set up the router as a WiFi access point".
