RobertFord0
Dec 27, 2022Tutor
FW 1.0.12.120 - RAX45 - Sonos Problems
FW 1.0.12.120 on RAX45 caused an issues with all of my Sonos devices. They could not connect to the network, even after I factory reset them. I spent over 2 hours with Sonos support. Next, I did a...
RobertFord0
Jan 14, 2023Tutor
Hi Iyang,
I cleared the Enable AX check box. I followed these instructions: https://kb.netgear.com/000060387/How-do-I-enable-or-disable-WiFi-6-features-on-my-NETGEAR-router
Thanks.
tedpoch
Jan 21, 2023Initiate
My Sonos Play:3 also has problems with this firmware V1.0.12.120_2.0.83 . I'm surprised not more people are complaining about this. Though I have seen a few other threads about problems with this new firmware.
The Sonos is unable to play songs from music services like Pandora, though it is able to configure the service account and retrieve channels, etc.
The Sonos is able to play songs from devices on the network.
And everything works fine with a wired ethernet connection.
Reverting to the previous router firmware resolves the issue and allows the Sonos app to play Pandora with a wireless connection.
