RobertFord0
Dec 27, 2022Tutor
FW 1.0.12.120 - RAX45 - Sonos Problems
FW 1.0.12.120 on RAX45 caused an issues with all of my Sonos devices. They could not connect to the network, even after I factory reset them. I spent over 2 hours with Sonos support. Next, I did a...
Oilmanjim
Feb 19, 2023Initiate
Same problem with RAX50 router. I also fixed problem connecting wirelessly by reloading older firmware. I even bought a 2nd RAX50 router thinking it was a router problem with the 2.4 GHz signal which my S1 Sonos uses. Turned out it was the firmware all along.
