Dauhee
Dec 01, 2021Aspirant
FW V1.0.4.76_10.1.82, R8000 - static IPs not being handed out as configured
Hi, I have static IPs assigned but some are not being handed out - has anyone else seen issues? The IPs that are not being set are for devices passing through EX7000 extender - yes I am using the...
Dec 01, 2021Guru - Experienced User
Static IP addresses on set ON devices. IP address Reservations are set ON the router.
Has this been a problem recently or has this worked up to a certain point then failed?
- DauheeDec 01, 2021Aspirant
yes thats it, configuration regarding reservation of IP set in "LAN Setup" against specificied MAC addresses is not being adhered to.
This functionality worked without issue on DD-WRT, I have just recently put stock V1.0.4.76_10.1.82 on and am experiencing the issue
- FURRYe38Dec 01, 2021Guru - Experienced User
Might revert FW version to something prior. Resent FW has not been good for users.
Thanks, I'm going to Open-WRT as Netgear FW updates appear to be problematic and couldn't be bothered spending the time rolling back to old insecure versions.
