Dauhee
Dec 01, 2021Aspirant
FW V1.0.4.76_10.1.82, R8000 - static IPs not being handed out as configured
Hi, I have static IPs assigned but some are not being handed out - has anyone else seen issues? The IPs that are not being set are for devices passing through EX7000 extender - yes I am using the...
Dauhee
yes thats it, configuration regarding reservation of IP set in "LAN Setup" against specificied MAC addresses is not being adhered to.
This functionality worked without issue on DD-WRT, I have just recently put stock V1.0.4.76_10.1.82 on and am experiencing the issue
Dec 01, 2021Guru - Experienced User
Might revert FW version to something prior. Resent FW has not been good for users.
- DauheeDec 01, 2021Aspirant
Thanks, I'm going to Open-WRT as Netgear FW updates appear to be problematic and couldn't be bothered spending the time rolling back to old insecure versions.
- FURRYe38Dec 01, 2021Guru - Experienced User
Good Luck.
- DauheeDec 02, 2021Aspirant
Thanks. I couldn't get 5Ghz wifi to work with OpenWRT.
I tried a November 2020 DD-WRT which bricked it. The older Kong version that worked for me up to now (very well I must add) was from Nov 2019.
So reflashing via serial and going to have to go back through each older version of stock and if I find one that is from 2020 I'll use that, otherwise will go back to what I had.
