Truthache
May 05, 2022Aspirant
Gaming NAT and latency RAX200 Help
1. RAX200 with 2 xbox series x on network would not allow open NAT for both consoles at the same time. Xbox settings》Advanced settings》Alternate port selection》 Manual》choose different alternate port ...
May 05, 2022Guru - Experienced User
Truthache wrote:
1. RAX200 with 2 xbox series x on network would not allow open NAT for both consoles at the same time. Xbox settings》Advanced settings》Alternate port selection》 Manual》choose different alternate port and now both consoles have open NAT. RESOLVED
Set NAT Fiter to OPEN for two or more game consoles being online at the same time.
2. Latency Issues over 60ms on both consoles. I have tried various troubleshooters and unable to bring it down. I switched from Spectrum 100mb to 1G plan and upgraded modem to arris sb8200 and router to the RAX200 to accommodate technical requirements for the speeds. Before the service upgrade average xbox latency was below 20ms. Any help or advice would be appreciated, guessing its the xbox servers but the timing of service and equipment upgrading etc. maybe an issue as well.How are the xboxes connected to the router? Wireless or wired? Wired is preferred
What is the CAT# cable between the modem and router? CAT6 is recommended.
Run a pingplotter.com with a wired PC connected to the ISP modem only and see if your ISP service line is showing good ping times
Truthache
May 06, 2022Aspirant
1 xbox is wired and the other is wireless, all wired components use CAT6 for connection. All other devices have average of 7ms ping. Only xbox consoles seeing high latency.
- Eric35May 17, 2022GuideHave you found a solution?
I have same issue with ping and high latency/jitter but with Android Box.- TruthacheMay 17, 2022AspirantNo solution yet for high latency to Xbox servers yet. Is it possible Xbox server locations need to be increased and upgraded to accommodate their customers? Maybe coincidence that preceding my latency issues and recently Xbox services had a worldwide major outage.
