Truthache
May 05, 2022Aspirant
Gaming NAT and latency RAX200 Help
1. RAX200 with 2 xbox series x on network would not allow open NAT for both consoles at the same time. Xbox settings》Advanced settings》Alternate port selection》 Manual》choose different alternate port ...
Truthache
May 06, 2022Aspirant
1 xbox is wired and the other is wireless, all wired components use CAT6 for connection. All other devices have average of 7ms ping. Only xbox consoles seeing high latency.
Eric35
May 17, 2022Guide
Have you found a solution?
I have same issue with ping and high latency/jitter but with Android Box.
- TruthacheMay 17, 2022AspirantNo solution yet for high latency to Xbox servers yet. Is it possible Xbox server locations need to be increased and upgraded to accommodate their customers? Maybe coincidence that preceding my latency issues and recently Xbox services had a worldwide major outage.
