Jcuffs10
Jul 08, 2023Aspirant
Genuine Netgear 2ABS060K, 332-11474-01 19V 3.16 A Power Supply
Im wanting to buy a Genuine Netgear 2ABS060K, 332-11474-01 19V 3.16 A Power Supply
- Jul 17, 2023
Good news, my RAX200 is back online working using a modified Dell laptop PSU.
FYI: 7.4mm OD is the Ground, 5.0mm ID is the 19.0V dc, and the center pin I broke off is a 5.0V dc to keep the laptop charge while it's off.
Conclusion: All you need is a 60w PSU that provide 19V dc with a 7.4mm coax plug without the center pin. Thanks to schumaku for the idea of using an old laptop PSU, you saved me $30+ and a week waiting for it in the mail.
Jul 08, 2023Guru - Experienced User
Try Amazon or online resources for power adapters.
- Jcuffs10Jul 08, 2023Aspirant
Yup! I have been looking with NO LUCK!!! Thanks
- schumakuJul 13, 2023Guru - Experienced User
This is a replacement power supply for your RAXE500, or for example an R9000 or similar? Look for universal notebook power supplies 19V, 3.16 A DC resp. 60W.
- Jcuffs10Jul 16, 2023Aspirant
I have and with ZERO LUCK!!!!
- michaelkenwardJul 16, 2023Guru - Experienced User
In what?
If you can't find an adapter that has Netgear written in the side, then, as both FURRYe38 and schumaku suggest, look for a "universal" power supply.
Why are you seeking a "Genuine Netgear" power supply? Netgear won't have it own transformer factory. They all come from one of those generic "adapter farms" in China or wherever the prices are currently most attractive.
Any generic adapter will work. Just get one with the right volts, enough amps and a tip with the right (+/-) polarity and dimensions to fit your hardware.
These things are pretty common, so first check to see if you have something compatible lying around.
The details you need should be on the old adapter, on a label on the device itself and in its manual.
You can find suitable adapters in all the usual places. Some will even list compatibility with different Netgear hardware.
Some generic adapters come with a set of tips that will fit a range of different devices.
Generic adapter
- schumakuJul 16, 2023Guru - Experienced User
In search of a replacement, or the rare situation a router does no longer take power from what is a new - hopefully working - power supply?
- steveofsdJul 17, 2023Star
I'm looking for the same PSU for my RAX200 which out lost during the move.
What is special is the plug, it's a 7.4mm OD barrel without center PIN.
I've check ebay and Amazon and both show the 2ABS060K With Center Pin. So just being 19v @3.16A isn't going to work.
This is like buying a 2018 Camry that has 3 different size tires depend on the model trim you buy.
