Jcuffs10
Jul 08, 2023Aspirant
Genuine Netgear 2ABS060K, 332-11474-01 19V 3.16 A Power Supply
Im wanting to buy a Genuine Netgear 2ABS060K, 332-11474-01 19V 3.16 A Power Supply
- Jul 17, 2023
Good news, my RAX200 is back online working using a modified Dell laptop PSU.
FYI: 7.4mm OD is the Ground, 5.0mm ID is the 19.0V dc, and the center pin I broke off is a 5.0V dc to keep the laptop charge while it's off.
Conclusion: All you need is a 60w PSU that provide 19V dc with a 7.4mm coax plug without the center pin. Thanks to schumaku for the idea of using an old laptop PSU, you saved me $30+ and a week waiting for it in the mail.
steveofsd
Jul 17, 2023Star
I'm looking for the same PSU for my RAX200 which out lost during the move.
What is special is the plug, it's a 7.4mm OD barrel without center PIN.
I've check ebay and Amazon and both show the 2ABS060K With Center Pin. So just being 19v @3.16A isn't going to work.
This is like buying a 2018 Camry that has 3 different size tires depend on the model trim you buy.
schumaku
Jul 17, 2023Guru - Experienced User
No, it's amazingly much more a common standard connector: It was originally designed for PCs requiring 60W, 90W, and 120W, often offered as PC ITX power supply as set Of course, there is a center contact, it's just designed different than the common barrel plugs.
- steveofsdJul 17, 2023Star
You just gave me an excellent idea, I found my old Dell laptop PSU (19.0V @ 3.9amp) that has a 7.4mm OD x 5.0mm ID plug, all I need to do is break off the center pin and I have a working PSU. Standby.....
- FURRYe38Jul 17, 2023Guru - Experienced User
I presume if you break off the center pin, could make it so won't work.
- schumakuJul 17, 2023Guru - Experienced User
steveofsd wrote:
You just gave me an excellent idea, I found my old Dell laptop PSU (19.0V @ 3.9amp) that has a 7.4mm OD x 5.0mm ID plug, all I need to do is break off the center pin and I have a working PSU..
nothing to break off - there is a protected center contactor. What you have in your hands is a 75 W power supply - perfectly fine.
